I have updated to 2023X version. The new render engine is set to default. The 3Dconnexion mouse is still not functioning with the new render engine. Does anybody have this same problem?
Roland
HI BliTec:
I don’t have a 3 d mouse can’t test, if I can help you test on ZW3D202 Ⅳ.
Is ZW3D202 Ⅳ a test version on which I can test?
Hi BliTec. I had the same problem and solved it by making the settings in the linked post.
(click on the word “image” to open the screenshot. Don’t worry that its in Polish - the button arrangement is the same in English)
Good luck.
Hi Designs,
Thanks for your answer. I know this because this problem was in 2023 version already and was marked as a bug, but it isn’t solved in 2023X
Roland
HI BliTec:
It is still a preview
