I have a query about “How To” set my file directories so that each time I am using a Project folder, I will always be defaulted to the same folder each time I want to open a ZW3D file.
I thought it would be the same path through Importing and Exporting for the same project, but what I’ve found is that at the moment ONLY the IMPORT of files keeps going back to the same folder.
Is there a way I can set up the directory options to sort this problem out?
