This is for ZWSoft Engineers…
Create a sketch with intersecting profiles.
Create new sketch and reference the profile curves.
Make trace profile of an enclosed shape with a circle arc edge…
The Shape is closed feature does NOT work.
Extrude the Trace Profile.
It is NOT possible to select the Trace Profile sketch, with or without the ALT option.
You must change the eslection filter to Sketch for the A:T [ick top work.
You can extrude if you pick the sketch from History.
Make drawing of part.
Select Peak point as a dimension option.
It is NOT possible to select the arc.
None of this is helpful to users.
How does this kind o regression occur?
Will it be fixed in the SP?
