101=Tag
102=Parametric List
103=Simple Attribute
104=Direction
105=Arrow
106=Curve-On-Face
107=Line Attribute Bundle
108=Surface Attribute Bundle
109=Dimension Attribute Bundle
110=Text Attribute Bundle
111=Hatch
112=Continuity
113=
114=3D Constraint
115=Window
116=Material Attribute Bundle
117=Unit Curve
118=Light Source
119=Interpolated Curve
120=Equation
121=Equation Set
122=Hatch Attribute Bundle
123=Symbol
124=CG Attribute Bundle
125=View
126=Group2
127=Name
128=3D Clipboard
129=
130=
131=Filter
132=Projector
133=Traced Profile
134=Trace Vertex
135=Trace Edge
136=2D Clipboard
137=Drawing Table
138=Drawing Table Column Format
139=Reference Component of View Layout
140=
141=Smart Point Input
142=Smart Constraint
143=View Layout Attribute Bundle
144=Table
145=Table
146=Optimize
147=Hole
148=
149=Point Attribute Bundle
150=Table Reference
151=Shade Edge Data
152=Data Reference
153=Embedded File
154=Triangle Mesh Vertices
155=Triangle Mesh Facets
156=Thread
157=
158=Level Of Detail
159=Triangle Mesh Vertices
160=Hierarchical Triangle Strip
161=Triangle Mesh Facets
162=Transformation Matrix
163=Animation
164=Animation Parameter
165=Animation Parameter Value
166=Animation Key Frame
167=Table Attribute Bundle
168=Balloon
169=Sheet
170=Sheet Border
171=Sheet Block
172=Folder
173=
174=Part Configuration
175=Configuration Entry
176=Break Data
177=Data Link
178=Entity Attributes
179=Display Attributes
180=Texture Color
181=
182=Break Line
183=
184=Pin
185=ReadySketch Text
186=dimension value
187=Exploded view
188=data of exploded view of component
189=PMI manager
190=PMI
191=Backup
192=Sketch3D
193=3D Constraint
194=Equation config
195=reference component
196=assembly own attributes
197=Sketch Block
198=Block Reference
199=Calculated Attributes
200=Cam Plan
