Bit of an issue with the ZW Cam…(scratching my head a bit ???)
Cant understand why its not outputting the Tool number in the Cam program output.
It’s a bit of a concern, especially when you doing multi tool machining, and currently I’m having to manually edit the Tool numbers.
Is there a separate option/ function I’m not aware of ……or is there problem with my Post. I’ve tried various other posts, but still getting the same result….needing your help, please
