Is there any way to change the transparency percentage of the “Toggle Entity Transparecy” command?
See image
See image
from appearance settings, there is a transparency slider.
Yes i know, but i wanted is to have an option to change the transparency percentage in the “Toggle Entity Transparecy” command, if it were possible.
Didn’t you take a simple macro file to the event and switch to an iPhone?
[vxSend,"!CdTransToggle"]
Hello zw3d_liangfen,
That’s what i was looking for. Thank you
In ZW3d 2025 non funziona
I work in ZW3D 2025 and works
