Hello, i have few questions about Structure module:
Can i add my own attributes in adding my own profile to Structure wizard?
I would like to merge this with the attributes I otherwise have in the BOM template.
Using the structure module, I create several identical parts, for example the end cap highlighted in red. But ZW3D manager treats it as multiple parts, even though they are identical. I would like to unify it so that it is one part.
If i want to make a hole in this end cap, is there any other solution than by Hole function in the Shape tab?
Can i understanf correctly, that Structure module is not available in Multi object mode?
Many thans,
Vojtěch
point 1 - Yes, you can add your own attributes to the BOM, but you must keep these five attributes at the beginning. It is important.
point 2 - From my point of view, there is only one solution: use a pattern or symmetry. I haven’t found a function that allows reusing an identical part or something similar. If you find it let me know
point 3 - You have to convert virtual part to the standard part, than you can used standard function as usual. Used right click on part and select used function “Make Independent”
point 4 - You have to convert virtual part to the standard part, than it will split into multiple files.
I hope it will help you.
Thank you Petr. It really helped
Hello, i have another issue/question. When automatic drafting, my automatic dimensions are snapping to unknown points (I assume it’s related to CSYS). How can I avoid this?
