Stp ap214 syntax error
My version fo zw3d is 2026 sp1. I try to export assembly in stp ap214. Every time I export some parts or assemblies to STP and trying opening in latest edrawings, I got missing parts. Assembly not showing completely. I found NIST step file analyzer, checking exported stp files. I got thousends syntax errors in stp files. And I found app CAD assistent. When I open this stp files in CAD assistent , having no issues. There is a option in CAD assistent to save it in new STEP file ap214IS. After CAD assistent when I analyze step file , I get no syntax errors. With this ap214IS, when I open in edrawings, having no issues. It opens comletely, nothing is missing.
Can anybody advise me, what kind of version stp ap214 has zw3d ?
Your workaround suggests ZW3D’s AP214 exporter is writing STEP entities/references that eDrawings rejects, while CAD Assistant is normalising or repairing them into an AP214 IS-style file. Check whether ZW3D’s export dialog has an AP214 IS or AP242 option and test that in eDrawings; if AP242 also opens correctly, use it as the practical export format. Otherwise keep the CAD Assistant re-save step and send ZW3D support the NIST analyzer log plus a small failing assembly, since the exporter rather than eDrawings is the likely fault.
