Share Zw3d API Development example
HI ALL:
Here are zw3d secondary development sample files, which can be compiled and run with vs2017. I have tried them. These examples are based on zw3d2020 API
Hope to help you!
Happy New Year!
这里ZW3D 二次开发范例文件,可以用VS2017编译并运行,我已经尝试过了,这些范例是基于ZW3D2020的API.
希望对大家有所帮助!
新年快乐!
ZW3D2020 API Samples based on VS2017
How to Use it:
  1. Install ZW3D 2020(https://www.zwsoft.com/product/zw3d)
  2. Use Visual Studio 2017 open the *.sln file
  3. Compile the project.
  4. Open ZW3D,Click the Application->Applications and Plugin Manager,switch to Plugin Applications
  5. Click Load Dll Button and choose the *.dll you compiled in step 3
  6. run the command you defined.
