Select edge contour
I need to create face at angle, in the following geometry.
I know execute the command by picking one by one edge. But is tedious work. The edges are not tangent. Is there any way to do it by one or two click, instead of doing one by one edge?
What’s the difference between pick and pick set? Could it be usefull?
HI TF_CAD:
Left key +Shinft
Ok, good!
And if I want to select only from one edge till another, any way?
What’s pick set?
Hi TF_CAD
When you are going to select edges you can right click in the graphic window and select “Pick curves” here you have different options, the second option could help you to select only from one edge to another.
Or in the “Pick Tools” toolbar you have some more methods.
Seleccion
You can also orient the model and window select with the filter active. If you end up with some you don’t ant, they can be identified in the list and deleted.
