Hello everyone.
Does anyone know if there is study material for the piping module?
In addition to the one in the PDF “What’s New 2022”.
For example about how to create my own template, flange libraries, etc, etc.
Thanks greetings.
Hello everyone.
Thanks greetings.
Go to the ZWSoft channel on Youtube an search for Pipe within the channel.
2023 Gets a Help section on Pipe Module.
Also if you look in Help/Training Manuals/More/ you should see a Manual on Config and Library.
Curiously on my copies of 2022 and 2023 there is NO Pipe module. So I have no Idea how that is delivered!
Zw3d 2022 pipeline team is a special installation package, and zw3d2023 installation package is directly built-in!
Hi Cowboy99,
Thanks, I’ve looked in the places you mention and there is some useful information on using the pipeline tools, but not so much on customization.
And I don’t know if you have tried “one object per file” because in multi-object it doesn’t appear as such.
Thanks Cale.
Nothing like that here.
Is it a Minor Module?
Check this from License Manager.
The license module is missing
Minor Modules: ZW3D_ADVANCED_MODELING
ZW3D_DIRECT_OPEN
ZW3D_ZWMOLD
ZW3D_SHEET_METAL
ZW3D_POINT_CLOUD
ZW3D_2AXIS_TURNING
ZW3D_2AXIS_MILLING
ZW3D_3AXIS_MILLING
ZW3D_5AXIS_MILLING
ZW3D_JT
ZW3D_FTI_BASIC
ZW3D_FTI_ADVANCE
ZW3D_KEYSHOT
ZW3D_WELDING
ZW3D_ELECTRODE
ZW3D_TRANSLATOR_2D
ZW3D_VOLUMILL
ZW3D_VOLUMILL_3X
ZW3D_PARTSOLUTIONS
ZW3D_FULL_MACH_SL
ZW3D_ECAD_MCAD
ZW3D_PIPING <<<<<<<<<<<<<<<<<<< ![]()
ZW3D_HARNESS
ZW3D_STRUCTURAL_STD
ZW3D_STRUCTURAL_PRO
Hello Paul,
Yes, it is a separate license module, if you do not have the piping license it is not activated.
