Permanently saved user property in BOM
Hi, I have a problem with the BOM user parameter. The thing is that when I create my own user property in the BOM in the attributes and add it to the BOM in the 2D drawing, it is displayed. Then I save the BOM as a template. So far everything is fine. But when I create a new part and insert the BOM I saved there with my own defined property, it is no longer displayed (user property) and saved. Any ideas how to do it or where is the mistake? I made a video of this issue - bom_issues - TechSmith Screencast
Thanks!
Is the User Attribute Part of your Part Template?
If not, it cannot be displayed from a new part.
Edit your Part Template by adding the User Attrib and Save.
Thanks for your respond.
Yes, i have User Attribute saved in Part Template. You can see it in the video attached in my post. Problem is, that i don´t how to save it permanently in 2D BOM template.
Still no one to help?
Hi VojteCZ, Maybe something different from What I have done in version 2022.
I created a new BOM template and filled it with a mixture of regular and user parameters.
I saved is under an unique name in the user folder of zw3d, not in the installation folder, which is always trouble with saving customized templates and libraries.
I keep the folder names for the customized stuff the same as in the original locations, only this path (below) is located in the user folder:
C:\Users<login name>\AppData\Roaming\ZWSOFT\ZW3D\ZW3D 2022\custom\supp\custom.Z3BOMTT
that folder can contain templates from BOM and also templates from the style manager in drawings.
If that fails in version 2025, I think that ZW support schould run some tests on their side.
Good luck!
Thank you for the tip Luurt. I tried it, but unfortunately it still doesn’t work. I contacted official support aswell, but any useful respond. I really don´t know how to do it.
Vojtech
Cloud you please provider data and your settings? I will take a look…
Hello/Ahoj
Which types of files do you need?
Thanks,
Vojtěch
Asembly with parts, drawing and your bom tempate…
So here is it. I cannot share assemblies, because of privacy, so only part, BOM and drawing file
Thanks!
Vojtech
I have check it and it is work properly…
You have to create template part with same name of user defined parametrs as you used in BOM tepmlate and it will work.
Thanks! The exact same name, that was the key.
Vojtěch
