it is possible to create a macro that creates a mirror part, copies the geometry from the reference part,do the symmetrizes, copies the parameters from the reference part and names acording example below…
example
Z0078-100_PLATE (reference part)
Z0078-100Z_PLATE (mirror part)
@Petrnejedly
hi
How does the software know that you need a mirror image of that plane?
![:joy: :joy:](https://zw3dforum.com/images/emoji/apple/joy.png?v=12)
HI
Is that right?
macro《《《《《The script is here.
test.mac (1.4 KB)
video ![:arrow_down: :arrow_down:](https://zw3dforum.com/images/emoji/apple/arrow_down.png?v=12)
Macro篇-国外老铁问如何派生镜像文件
we always use the YZ plane.
I tried this macro, it works fine, but I need to connect the reference part and the mirror part.
So I want to use function “geom to par”.
![image](https://zw3dforum.com/uploads/default/original/2X/e/e4e8f6d157eed5d876b0bc124186f9d4a4c1a8e5.png)
It should work like:
- create a new part
- renamed as reference part and after position number put “z” like “Z0078-100Z_PLATE” (100 is the position number)
- copy geometry use function geo to part
- do the symmetry YZ plane
- copy the user defined parameters
HI
It can be written, but it takes time.
Maybe you should try it yourself.!
Yes, I will try but is it possible by VX macro or it is nesesery use c++?
