I got this command to work. The two models have to be at the exact same coordinates for it to work. Unfortunately, the result is not to useful. Most of the result is red but since it does not allow you to enter any type of tolerance Im not sure what that means. Red just means one is fitting inside each other. The Blue coloring is minimal and green which implies an exact match is only in two spots. Physical measurement of the actual parts imply should see much more green.
Thanks in advance for your input.!
Yes, this function is very useless!
