Hi , in zw3d 2019 it was possible to copy/paste parts by hitting ctrl+c then kip ctrl + v in part manager , then multi insert those parts and changing the parameter of one part wouldn’t affect the others , but in zw3d 2022X there is no way to multi insert independent parts , i even tried to unlink parts by clicking on “make independent” from assembly manager but it didn’t help .
HI hamed.desighn:
My software is normal. There is no problem copying and pasting components. I suggest you completely empty the configuration file and try!
HI hamed.desighn:
You can also try Shift + Alt + left click to copy!
你也可以试试shift+alt+左键去复制!
nah Whenever I copy paste parts the has the same name and they are linked to each other while in 2019 version files names become like this : part.001, part.002,part.003 …
The single file mode is enabled by default since version 2022. Is your file suffix Z3ASM?
Yes , how can i revert it back ?
Configuration Utility.
There is a tick box that sets Single Object/Multi Object.
Cheers -Paul
can’t find it , there is just a new assembly mode which grayed and enabled and i can’t disable it
