i’m using zw2023 and i have found this issue when i make an independent copy and leave the default rename suffix option.
i have create “fisrt_part”, then copy it (ctrl-C → ctrl-V).
then, as in the picture, I’m making an independent copy of “fisrt_part”, and leaving the suffix name “_1” as suggested.
But when i ask “information entity” it gives this results:
Same old name in “configuration table”
Tried to rename it but wont work.
If i make an independent copy and change the suffix (for example “_COPY”) , everything goes well.
is there a way to change those property?
