Hi everyone,
When can macros develop ides like ILOGIC?
We need simple UI making tools like it!
There is also a code segment management tool, which is also fast to write code!
Hi everyone,
Hi Liangfen, if you need a tool to create simple forms to be associated with your ZW macros, you can use QTDesigner.
HI Axion_srl:
Thank you for your reply.
感谢你的回复.
I’ve got official help and tried
我已经得到官方的帮助也尝试过了.
Have you ever done a case with a button?
你有做过带按钮的案例的嘛?
At present, I try to make code fragments for him.
目前我尝试给他做代码片段
this is the form which works with our MULTIPLE UNFOLD macros… as you can see it contains button, combobox, textbox etc…
HI Axion_srl:
What I hope is that there are many small buttons above. I press that to call the corresponding sub macro.
我希望的是上面很多小按钮,我按那个调用对应子宏.
HI Axion_srl:
If you can, can you share this * Give me the UI file, thank you.
如果可以的话能否分享你这个*.ui文件给我,谢谢.
