How do I stop the twisting?
Just need to loft 50mm square to 50mm circle over a distance of 50mmLoft.Z3 (44.4 KB)
Hi Iain,
by default, lofting will connect vertex to vertex. Each circle has a nominal start point which is equivalent to a vertex.
Options
Use move to rotate the circle … nah don’t do that.
In loft you have controls.
One of these is edits, deletes, modifies connector lines.
You modify the existing connection line end point by selecting it the repositioning the point.
Or try Smooth option.
If that does not work, then modify as above.
Thanks.
Sorted.
Iain
