Just upgraded to 2024
no lock rotation option is available in concentric constraint in assembly
please check image
If I open old file all concentric constraint is in red color with x marks
Any solution for This?
@PDPatel
HI,I don’t know when your installation package is. My 2024 official installation package is normal!
@PDPatel
From the picture provided, your package should not be the latest version, the latest date is 4/21
版本 : 中望3D 2024 x64(28.00)
VERNUM:04/21/2023(155165:91259ab7b86a)
Using same version
Try concentric constraint with point and circular face
with both circular face it works ok
@ PDPatel
I haven’t played this kind of operation, usually it’s axis to axis.
Hi PDPatel:
I just tested the old version, as you said, point + axis mode can lock the angle!
I used to use this mode to select only axes and axes! ![]()
