So easy and such a simple single tool to do everything.
Why anyone would want to complicate it by division eludes me.
I expect the computer power to more for me, not less.
Customise/Transfer/Ribbon/Search All/!FtBoolAll/Drag on Ribbon Panel Position.
![vxSend,"!FtBoolAll"] works perfect but it is not convenient to type each time
Customise/Transfer/Ribbon/Search All/!FtBoolAll/Drag on Ribbon Panel Position is not working for me
combine command is locked in panel
please check image below
Thanks for replay
nice video
I crate script record and edit script file as per your video
But I do not understand how to run
After closing script record at 3:15 what are you doing next?
Bottom side is not visible and no any audio
Just one step ahead required
If possible share edited script file, there are some other language word at last which I not understand
HI PDPatel:
I have fed back this instruction to the Guangzhou headquarters. Maybe I can call it directly in the future, so we don't have to bother so much.
That is a real pity.
For ZW3D to grow it needs an amount of User Customization capability that is easy to access and use.
Does ZWSoft even think this way?
Hi, I deleted my previous post about not working 2023X. After installation it was overwriting my 2023 environment expert settings and set it to default intermediate.
And I changed it in expert enviroment and have seen that it was added in registry but not in expert for sure (my mistake, looked in wrong environment). So I assumed it’s not working, but it is. All is fine again working
Hi Caddie, thats cool. Thanks for the update. My apologies to ZWSoft on that one too.
The problem is that ZW are a bit sloppy about UI sometimes…
Role manager is screwed up. The priority of the default options is wrong.
Maybe in China Advanced is higher than Expert?
