In case that you have part with wrong orientation of CSYS (for example for turning - rotation axis is not x). How to correctly change CSYS orientation?
I tried it using Align move command, but in case when the axis of chosen surface is not in center, then switched CSYS is outside of center as well. I replicated this problem and recorded video.
Thank you for your advice.
