does anyone know how to turn off imported PMI dimension?? I have opened assembly and each part have this annotation. I have to click to each part and hide it. It is horrible job.
Hello
Go to:
Edit - Copy - External Part
or
Edit - Copy - Geometry to Part
Hello, but I need hide PMI dimension… I have imported it from step file and I want to hide in upper assembly.
Hello
Can send the file?
In 2024 you have an import filter for PMI/Block.
In earlier Versions I export it again as Step with filter on Dimensions and reimport it.
Then you can work with two files. One with and one without PMI/Blocks.
