Hello everyone. Would someone remind me please how to hide specific line in 2d sketch? I’m pretty sure there was option for that (Picture 1). I tried option “hide elements” but it doesn’t work (Picture 2).
ZW3d 2025 Standard
ZW3d 2025 Standard
Try this. Make a new layer and move the line to the new layer and hide the new layer.
Roland
I can blank the lines in ZW3D 2025
Hi Piotr,
Lines are controlled by View Attributes.
That should be enough to remind you.
Cheers Paul
Thank you all for help. I tried option that you suggest and it is working. But i found something new. I tried do the same that you suggest before asking you and now I see why it doesn’t worked for me.
As i see, If I try to hide line in standard projection on 2d documentation it is working but view atributes doesn’t work on the unfold sheet of metal. This is the situation what I had.
Any ideas or it is program issue?
Hi Piortrm which lines are you trying to hide in Unfold?
Hi. The main line of the unfold sheet metal element. It was specific situation. I made wrong normal cut but I could repair unfold element by hiding unnecessary line. Then I found out that it doesn’t work in unfold sheet metal in 2d documentation.
