this option is available through Configuration-Display-Tangent edge display (Visible-Dashed Line-Remove). I am often swapping between Visible and Remove and I was wondering if there is any method to assign an hot key (or a button) for a quicker access to it?
Hi Ropa, if there is a Command for the task, then you can set up a HotKey or add the Icon to a Toolbar.
RMB a tool bar and choose Customize.
You might need to do a bit of learning on the Topic.
Just remember to set up a Customise Role in Role Manager.so you can save the customisations.
Cheers, Paul
thanks for your feedback! actually this is what I was trying to achieve but I could not identify such a command in the list. I now found a solution to this recording a script and assigning a Map Key to it.
