Is there any cad viewer for zw3d like Creo viewer (pvz format) or 3dxml viewer from DS or JTtoGo viewer from Siemens?
I hlave tried CadBro but it is too slow…
How can you share 3D Data to your customer or your manufacture?
hello,
i don’t think there are “only viewers” for native zw3d files.
Some of my customers don’t have any 3d viewing program, so I make them a 3d pdf.
For the others i normally use the step format.
Hello
If using ZW3D 2025
choose 3D file,
File - Export - *.html
and be happy!
I am using export via html, it is nice but if you have a bigger assembly it is a problem to open the file in the web browser.
I have used creo viewer (pvz file format) and it was possible to open big assembly on low end PC so I would like to have a similar solution.
Any idea?
ZW3D has a viewer but it is not free, but Zwsoft has an alternative which is CADbro. But it’s not free either.
Hello, yes I know, it is free if you want to open only z3 file, but as I wrote previously it is very slow if I compare with ZW3D…
I have simple questions but answer is difficult…
I have created an assembly that has individual parts and subassemblies and I would like to convert them to a single-file system z3 file.
how do I do that?
I know that the reverse way is easy to do.
I have tried CADbro 2025, it is free if you open only ZW3D 2025 file, but I have problem with the power.
I tried open a little bigger assembly and It seems that Cadbro 2025 is much slower than ZW3D 2025.
Does anyone have experience how setting up Cadbro to work faster, it has a very slow response time?
I don’t think there is a reverse way automatically, only manually.
