Fillets in Section View
Hi Guys, This has been bugging me for a while. If I section a part all is good…
FilletSection1
When I Invoke a Fillet Feature…
FilletSection2
Had this in Z32019 and now in Z32020
Running a Quadro K2000, and yes, I hear you say ‘that’s not a real graphics card!’…
Any Ideas?
W
Hi Wayne,
I am also running the K2000 and I do not see anything like that.
I wonder if it is model specific?
Have you blanked ALL Wire frames - RMB/BlankAll
Hi Wayne
I have seen that before.
I think I had to change the radius of the fillet to something silly and then go back to the right number, which seemed to fix it. Have only seen it on internal fillets though.
Regards - Ken
Thanks Guys,
There are no wire frames in this model, we are seeing some of the edges of connecting faces in the cut portion of the section view.
Thanks for the workaround Ken!, setting the radius to 0.01mm fixes the view visibility to allow adding edges.
For the Z3 Dev’s reading along, it’s a cumbersome workaround, and appears to be all models, at least on my rig.
W
