Started using 2024 recently
extrude add not support multiple shape
I try to create head for pin but only single object selection is possible
please check image
any solutions?
please check image
any solutions?
ZW could fix it.
Its broken.
Not helpful eh.
In your simple case… Extrude Face/Thicken or Shrik/Expand.
Thanks for reply, but not working
It add only one shape instead of three in Boolean
The best workaround I can find is to just extrude all faces as “Base”
Then add all extrusions by using the well hiddden Legacy booleans option.
Additional comment, the other two options in extrude do accept more shapes in the input field.
Surely a bug!
Thanks for reply, I know that
Same thing happen in revolve, block, cylinder
