Hello all
Since a short time I have an error message when I want to change something on my object. I can’t find a setting for it nor can I find anything else. I can create new sketches and extrude. But after that they are also frozen and I can’t change them anymore.
Welcome to join. I think you may be caused by referring to the loss of an object. This is very common. Do you check whether the parent object is still there?
欢迎你的加入,我想你可能是参考某个对象丢失了造成的,这很常见,你检查下父对象还在吗?
Hi and thanks for the answer.
I can not find something that would be loss there. I get the same message when i try to open a sketch.
The references there are just for the equation.
