Hi there.2021-05-25T22:00:00Z
I am on Windows 10 Pro, ZW3D version 2021.
Occasionally I ma getting red letter errors in the “OUTPUT” window(example screen shot attached).
The error itself doesn’t help me much, unless I can look up explanation of some sort and how to possibly fix it suggestion…
Is there a booklet with list of errors and deeper look at possible causes and solutions???
Hi Resu,
maybe you run the Clean File command.
Look it up in the command Search - Top RH corner of your screen.You can add it to your DAT via Customise Toolbars - RMB on Toolbar and Drag and Drop in the Transfer tab.
Cheers -Paul
