I have problem when I edit variable name in first part, second part which has imported external variable name in not changed in bracket, it has old name and lost connection with original variable
create part001 in multi object file and create variable name A
create part002, open variable browser, reference external variable, and import variable A from part001
working ok, any change in variable A in part001 also update in part002
Now the problem is if I modify/rename variable name A to xyz in part001, part002 external variable not changed and and link broken with old variable
This happens in 2024, in older version it works perfect
