How can I display the Construction Geometry in an Inactive (Unblanked) Sketch?
I would like to select Construction Geometry as references for other Sketches.
Wayne
Hi Wayne,
you cannot.
But you can make a Sketch Block which can be used again and again, either connected to the original or as a copy.
Or you can simply copy the sketch and make its construction geometry active and then place it at the top of you tree. - (Assuming you manage any chronological links)
Thanks Paul, I’m not missing something.
W
