Dear all,
Has one of you experienced the following?
A customer created a fairly simple assembly of a chair, which mostly contains sheet metal components.
The assembly was built from approx. 20 components and after creating an exploded view, 4 of them got corrupted by the command.
When opened from the assembly or directly in the file of the component the system jumps in exploded view mode and can’t quit from it to get to the history and regular ribbons layout
It starts with the message that it can’t create an exploded view, which is logical, since it is a part.
After exiting the error the part shows up in the exploded view mode without any option to get out of it.
So the part can be considered as lost if you don’t have revision backups from before the exploded view action.
See attached pictures
