Dear members,
In V2022 the base field in the trim and divide operations allow only one shape to be picked.
Please review attached picture and try to trim all cylinders in one command with the surface.
Dear members,
HI luurt4c:
I think you may have forgotten to upload something!
Ciao Iuurt4c ,
se quello che vuoi ottenere è come ti ho allegato , devi procedere in
questo modo . Stai utilizzando una superficie con dei solidi .
Ciao Ciao
I have added the “legacy options” back to the ribbon.
Honestly, I found the reason for hiding this options a bit weak, when I consulted ZW3D support about it.
They were supposed to be unstable, something that I have never noticed in all versions.
Mind you, I have worked with the system since VX version 7, so, way before it became ZW3D and never experienced any fundamental instability with it.
Second reason for doubting these arguments is that I can’t imagine that all main stream CAD software only has the option for selecting one shape at a time.
In that respect it could be seen as a regression.
Perhaps other forum members can share their opinion about this?
HI luurt4c:
I think it may make the algorithm problem; Perhaps it is to avoid the user’s misoperation of multiple choices, resulting in a crash!
我觉得可能使算法问题;也许是避免用户误操作多选造成崩溃!
