Hi everyone, how is it possible to change the default settings that always come out as “aluminium”?
Is it possible that when opening the file I can set the material I want?
Hi Rotolo,
You can use the template file or just create a macro to do this.
Maybe someone has a better solution.
Hello Jose,
I think it is possible to set it as default in the standard Part template.
I have created some part templates for a sheet metal company with different default materials and bend tables attached.
The most used one is then set as default at startup
That works well.
Hi luurt
I totally agree
