BUG: Datumplanes in "Publish Set" but are not in "External Geom Copy"
Creating a part to be used as a reference part in other new parts(2…n) by ‘External Geom Copy’, You can also select the datum planes into a ‘Publish Set’.
But when you select the datum planes in the main part with ‘Drag Datum’, even not modifying in size and just select OK then those datum planes disappear when you want to use the ‘Publish Set’ in your new part using the ‘External Geom Copy’ feature. Also, already used datums disappear in existing parts as well.
This is something in 2025(SP2).
To my opinion was this not the case in the 2024 version.
How can I get those datum planes back when I use the ‘External Geom Copy’.
It’s a major problem for me. I can’t continue
Thanks,
Roland
