2020 introduces more nuances for figuring out what is not right…
BLACK - the normal constraint color - everything is good.
BLUE - Item is blanked. Constraints will also be BLUE
RED - constraint is Over Defined and needs to corrected.
MAGENTA - Constraint is over defined BUT object is in correct position. In other words you are getting the result you want but the constraint is still in conflict.
I hope that is some help.
