Adjusting the window size in ZW3D
Is there a way to customize the window size in ZW3D and save it permanently? Even after restarting ZW3D.
Many thanks
Hello, ZW3D 2026 is now available, but I’m still having trouble with the window size.
In the settings, there’s an option called “Window Display.”
Can someone tell me what this setting does?
As I said, I want to adjust the window size so that it stays the same after restarting ZW3D.
Can anyone help me?
Those settings control how you see the display and where things go when you RMB. Experiment to see what changes.
Cheers, Paul
Nothing changes for me.
Where can I change the window size?
