I’ve read the manual Macro.doc but still no luck.
Any advice, thank you
HI
You don’t know enough about it.
[vxFormItemGet,form_name,field_id,item,isOn,data] #窗体条目获取1
[vxGet,form_name,field_id,item,isOn,data] #窗体条目获取2
This table operation involves algorithms, this information is missing, I have been looking for the old version of the vx installation package, looking for traces, but did not find, then I found the reason myself,
OK, I will try it…
I have second problem. If I run the code below twice the “upade on save” value is overwrite… I mean that check and uncheck…
Is there any function to prevent this?
[vxSend,"$SF=UiPartAt"]
[vxSendEvt,“UiPartAt”,1000,3,2]
[vxSendEvt,“UiPartAt”,73,1,2,"|Enter"]
[vxSendEvt,“UiPartAt”,72,1,2,"|Enter"]
[vxSendEvt,“UiPartAt”,120,4,2]
[vxSendEvt,“UiPartAt”,120,2,2]
@Petrnejedly
HI
code ![]()
# Author - 金州锅锅
# Date - 2024/7/1
# Version - 29
# Description
MACRO main
[vxSendEvt,"UiPartAt",1000,3,2]
# 保存数据时更新
[vxFormItemActive,"UiPartAt",73,item] #窗体内容判断
IF (item=0)
[Print,"Active:",item]
[Print,"NO"]
ELSE
[Print,"YES"]
ENDIF
IF !(item=1)
[vxSendEvt,"UiPartAt",73,1,2]
[Print,"====OK"]
ELSE
[Print,"========>OK"]
ENDIF
[vxSendEvt,"UiPartAt",72,1,2]
[vxSendEvt,"UiPartAt",120,2,2]
ENDMACRO
Thank you very much, it works perfectly.
I am trying to use API for crate macro for user parameters but…
In the reference is these example
//suppose that there is an expression named "aaa" in active part.
strcpy_s(attributes[1].name, sizeof(attributes[1].name), "str1");
attributes[1].[type](structszw_user_attribute_ace4c7203fba15a940781e058b16029a8.html%22%20%5Cl%20%22ace4c7203fba15a940781e058b16029a8) = [ZW_USER_ATTRIBUTE_STRING](group___zw_basic_data_gad4dff9862a9d5a44d771a07571cc29c1.html%22%20%5Cl%20%22ggad4dff9862a9d5a44d771a07571cc29c1afebf4975bdee77d642928087b0779f1e);
strcpy_s(attributes[1].uzwsubAttribute.szwStringAttribute.value, sizeof([zwString512](group__zwapi__util_gaf0ce0f9ae4a97081f7d831fe88cc2863.html%22%20%5Cl%20%22gaf0ce0f9ae4a97081f7d831fe88cc2863)), "[$aaa]");
Function szwStringAttribute it shoud be in zwapi_attribute.h but there is missing.
